Virtualdub 1.10.4 Released
Posted: Oct 27 2013, 11:42 PM
1.10.4 is out. Finally got a little slack time, and I figured I needed to push out a release some time or else....
Build 35491 (1.10.4, stable): [October 27, 2013]
  [features added]
  * ExtEnc: Added %(outputbasename) to insert output filename without
    extension.
  * ExtEnc: Editor UI now has a drop-down for tokens.
  * Filters: Expanded color space support in resize filter.
  * Preview: Return now also stops preview.
  [bugs fixed]
  * AVI: Added Copy button to AVI file information dialog.
  * AVI: Fixed bitsPerPixel value for NV12 output.
  * Capture: Improved error handling in screen capture module.
  * Capture: Fixed sporadic errors in DXGI 1.2 screen capture mode related to
    tracking pointer shape changes.
  * Capture: Spill drives can be adjusted on Windows XP.
  * Display: Fixed regression in D3D effects display mode.
  * ExtEnc: Fixed weird selection behavior when duplicating item.
  * Filters: Fixed script operation for Convert Format filter for the new
    modes.
  * Filters: Fixed crash when attempting to crop video in a format that isn't
    AVI-compatible.
  * Filters: Fixed cropping errors on alias format filter.
  * Filters: Fixed issues with interpolate filter in nearest mode.
  * GIF: Fixed shifted presentation timings when reading animated GIFs.
  * Render: The processing priority setting now correctly adjusts the
    priority of filter and compression worker threads too when multithreading
    is enabled.
  * TARGA: Fixed vertical inversion issues during read.
  * UI: Add Windows 8.1 per-monitor DPI awareness support.
Posted: Oct 28 2013, 07:48 PM
Thanks Phaeron for the new stable release 1.10.4.
I wonder if everybody knows where to find it ?
So here is a hyperlink : http://virtualdub.sourceforge.net/
v0lt
Posted: Oct 31 2013, 05:57 PM
Thank you.
*.vdf and *.vdplugin files should be put in "plugins32" folder only?
Can I continue to store *.vdf files in the "plugins" and *.vdplugin files in the "plugins32"?
What is the status of "plugins" folder?
Posted: Oct 31 2013, 06:32 PM
"plugins" is a legacy from the old versions
The newer versions of virtualdub look first in their own 'bitness' plugin folder and then for backwards compatibility the "plugins" folder
So,
virtualdub 32bit searches plugins32, then plugins
virtualdub 64bit searches plugins64, then plugins
.vdf files can pretty much go anywhere (they're scripts not binary executables) unless they're ones that the plugin loads itself automatically - in that case, put them in the same folder as the plugin
3 replies since Oct 27 2013, 11:42 PM Track this topic | Email this topic | Print this topic
