Virtualdub 1.10.3 Released
Posted: Dec 28 2012, 12:24 AM
1.10.3 final is out. Happy holidays, everyone.
Build 35390 (1.10.3, experimental): [December 27, 2012]
  [features added]
  * Added option to control whether edits on the timeline are applied to
    audio.
  * Capture: Added support for screen capture via DXGI Output Duplication in
    Windows 8.
  * Capture: Added support for Core Audio loopback capture in the screen
    capture driver on Windows Vista and later.
  * Script: Improved error reporting for script errors during job execution.
  * UI: Added option for confirmation on exit.
  * UI: Program is now marked as high-DPI aware.
  * UI: Added /topmost flag.
  * AVI: Add .vpy extension to AVIFile path.
  * AVI: AVIFile mode path now allows Unicode filenames.
  * Filters: Convert format filter can now target Rec. 709 and full-range
    YCbCr formats.
  * GIF: Animated GIF exporter now uses subrects and adaptive local color
    table sizes.
  [bugs fixed]
  * Grayscale/Y8_FR video displays properly with GDI and DirectDraw display
    back-ends again.
  * Fixed the main data chunk size in WAVE64 files being 24 bytes too small.
  * Fixed garbled status message with /F flag on x64 build.
  * Fixed scanline alignment on V210 format to 128 bytes.
  * Capture: Fixed regression in the bandwidth indicator from increase in
    frame rate precision.
  * Capture: Fixed crash in DirectShow mode when selecting an audio device
    that has been removed.
  * Filters: Fixed garbage initial value for format convert audio filter.
  * Filters: Fixed crash in ELA modes of the bob doubler.
  * Filters: Fixed degree sign in rotate2 and HSV filter blurbs on
    non-English systems.
  * Filters: Fixed inverted images with field swap and deinterlace filters
    with RGB24 input.
  * GIF: Clear codes are now forced when the LZW table fills up to work
    around buggy decoders.
  * Script: Lifted some line length limitations in script handling.
Barough
Posted: Dec 29 2012, 12:59 PM
So this is really the new Final/Stable version then. VD's website still 'list' 1.10.3 as Experimental and so does it on the SF project page.
Posted: Jan 6 2013, 11:20 PM
It's still experimental, since the last release had too many regressions for me to have confidence in this one yet. But... if all goes well, 1.10.4 could come out relatively soonish as the new stable.
Once I do that, probably the first thing I'll do is drop Win98/ME support for the new experimental branch. Haven't decided if I want to upgrade compilers yet... I'm tempted to go to VS2010 Pro for the 'auto' keyword and for rvalue references. I tried VS2012 a bit and the UI seems to suck a bit too much.
Barough
Posted: Jan 7 2013, 05:23 AM
Thnx 4 the info/reply. smile.gif
kenmasters1976
Posted: Mar 16 2013, 07:27 PM
I'm not sure if it's a bug but I can't setup spill drives in Windows XP (I can't edit the path field). I had to manually edit the registry entries to set it up.
4 replies since Dec 28 2012, 12:24 AM Track this topic | Email this topic | Print this topic
