Virtualdub 1.9.11 And 1.10.0 Released
Posted: Dec 24 2010, 10:28 PM
Announcement on the blog to come shortly, but they are already up on SourceForge. 1.9.11 is a minor stable release and only contains the added support for filter compatibility mode; 1.10.0 is experimental and contains everything that was in the 1.9.X test releases.
Build 32842 (1.9.11, stable): [December 24, 2010]
  [bugs fixed]
  * Filters: Added compatibility option for filters that rely on constant
    buffer addresses.
Build 33848 (1.10.0, experimental): [December 24, 2010]
  [features added]
  * Holding the Ctrl key during drag-and-drop appends instead of replaces.
  * "Scan for errors" command is now scriptable
    (VirtualDub.video.ScanForErrors).
  * Save Animated GIF command is now scriptable
    (VirtualDub.video.SaveAnimatedGIF).
  * Added ability to import and export raw video.
  * Added ability to export through command-line encoders.
  * Added support for 0-255 paletted grayscale.
  * Added support for Rec. 709 and full range formats.
  * Added command to copy source and output frame numbers to the clipboard.
  * Render: Added option to show the status window for batch operations.
  * Render: Video compressor threading is now allowed for two or more threads
    when operating with only key frames.
  * Filters: Added multithreading support.
  * Filters: Added "gamma correct" filter.
  * Filters: Added "alias format" filter.
  * Filters: Re-added deblurring mode to IVTC filter and added preview
    support.
  * Filters: Added frame drop mode to IVTC filter.
  * Images: TGA RLE compression can now be disabled.
  * Images: Added support for PNG alpha channel.
  * Capture: Multiple capture devices with the same name now appear with a
    distinguishing counter.
  * AVI: The non-zero start warning can now be disabled in preferences.
  * AVI: The number of filename counter digits used when saving segment
    sequences is now configurable.
  [bugs fixed]
  * Reduced priority of ASF pseudo-handler to avoid interfering with input
    handlers that detect by filename.
  * AVI: The preferred handler (fccHandler) field in the video stream is now
    ignored by default for consistency (unless re-enabled in preferences).
  * UI: Limit minimum window size to avoid caption redraw artifacts.
  * UI: Fixed bug where aspect ratio of panes in unconstrained aspect mode
    would drift when auto-sizing was enabled.
  * UI: Select Range command is now disabled when no video is loaded.
  * UI: Audio conversion dialog no longer occasionally says "No change
    (8-bit)" for compressed formats; this was sometimes incorrect as when
    that option was selected the pipeline actually used what the codec
    produced, which was usually 16-bit.
  * UI: Video codec dialog now scrolls the list on open to always show the
    last selected codec.
  * UI: The Configure and Cropping buttons in the filter list dialog no
    longer lose focus when clicked.
  * UI: Mouse wheel scrolling now works in the filter preview and curve
    control windows.
  * JobControl: Auto-shutdown now works over remote desktop and records a
    planned shutdown on server versions of Windows.
  * Images: PNG images with 16-bit/channel grayscale or RGBA format now load
    properly.
  * Images: Fixed GIF autodetect code checking the footer instead of the
    header.
  * Hex editor: Fixed icon in RIFF tree window.
  * Filters: Switched the frame that the IVTC filter drops in reduce frame
    rate mode to match the old pre-filter algorithm.
  * Filters: Cropping dialog now opens at the currently selected frame.
  * Filters: Fixed warp sharp filter in 3D acceleration mode.
Jam One
Posted: Dec 25 2010, 05:04 PM
Thanks a bunch, and Merry Christmas!
v0lt
  Posted: Dec 25 2010, 07:43 PM
Thank you! Good gift!
EasyRider
Posted: Dec 26 2010, 12:52 AM
Hey phaeron, you can call this release "2" mate!
Thank you for the external encoder support. Excellent work. !!! biggrin.gif biggrin.gif
MaxS
Posted: Dec 28 2010, 01:48 PM
QUOTE (phaeron @ Dec 24 2010, 10:28 PM)
    properly.
Nitpick: PNGUnpackIndices16Bit() is not needed, because 16-bit depth does not exist in palleted mode.
jptdxh
Posted: May 20 2011, 10:19 AM
Hi, just installed vobsub and configure it with virtualdub during installation but when I am going to add .srt subtitle it doesn't respond. It's like nothing is going on.
Is there any way to make virtualdubmod filter to work with virtualdub?
EDIT: I got it to work the vobsub and textsub filter now.
freedomdwarf
  Posted: Jul 16 2011, 10:19 AM
Nice lot of fixes but has anyone noticed the bug in Job Control in v1.9.11 and v1.10.0 releases??
I have emailed Phaeron (twice) a while back (2 weeks ago) but got no reply as yet.
For those that haven't spotted the problem, this is what I get -
In essence, I cannot get it to do a folder/directory and keep the settings between each job to be processed.
I set everything up (audio & video settings, compression, filters etc) and when I start JC the video compressions are completely reset to uncompressed on every job in the list and the filters are being ignored sad.gif
The audio settings are fine and are remembered, but the video ones aren't.
It used to work in earlier versions of VD but not the latest few updates and the beta version.
As an example, A simple black & white TV series that I'm cleaning up would usually take 3-4 minutes each for the 26-minute clips but I would have to do each one manually - hence the use of the 'process directory' in the job control.
For 39 episodes, that's a LOT of manual intervention when JC could do it in a single stream for a couple of hours or so uninterrupted (it actually took *6* days in practice under 1.9.10 instead of a few hours!). In VD v1.10.0 they were taking 5-6 mins each.
Each clip is about 150MB and recoding it into AC3/DivX6.9 should yield 120-130MB files but with the compression being reset they are ending up at over 22GB each!!
I have a fair bit of HD space but I don't have 800Gb free! lol.
Just an update - VD v1.9.10 seems to be working correctly and remembering the video settings - VD v1.9.11 and v10 beta don't.
So I guess something got broke somewhere in the update?
Just as a side-note which might help, in v1.9.10 when processing JC, I DON'T have a progress box showing whilst it's doing each file (just the VD main window with the input/output video and the Job Control window) whereas with v1.9.11 and v10 beta I have the usual progress box (project stats, perf etc) showing with each file being processed just as if I were doing a single file manually.
Dunno if that helps to pinpoint the hiccup.
6 replies since Dec 24 2010, 10:28 PM Track this topic | Email this topic | Print this topic
