Virtualdub 1.9.3 Released
Posted: Jul 5 2009, 11:52 PM
Build 32507 (1.9.3, experimental): [July 5, 2009]
  [features added]
  * UI: Added options to display only one of the panes and to autosize them.
  * Filters: Added support for 3D hardware acceleration.
  * Filters: Invert, warp sharp, blur, blur more, brightness/contrast,
    deinterlace, and resize support hardware acceleration.
  [bugs fixed]
  * Drag and drop onto the batch wizard now works in Windows Vista and
    Windows 7.
  * Go To Prev/Next Drop command now works after the timeline has been
    edited.
  * Fixed random frame codes on the one-after frame.
  * AVI: fccHandler header value for newly generated uncompressed videos with
    non-RGB formats is now set to the FOURCC to work around encoders that
    don't accept DIB.
  * AVI: Fixed bug where zero-byte pad frames were lost if the video stream
    had a non-zero dwSampleSize value set.
  * Filters: Cropping button is now grayed out for disabled filters, since
    the input size is unknown.
  * Filters: Fill filter now shows correct input size when there are earlier
    filters (although, currently, the image is still incorrect).
  * Filters: Fixed bug where crop bounds weren't recorded correctly if the
    up/down buttons were clicked and a thousands separator appeared.
  * Filters: Fixed random crash in interlace filter when switching formats.
  * Filters: The manual field order options in the IVTC filter were flipped.
  * Filters: Resize no longer forces a conversion to YV24 when resizing YV16
    input in interlaced mode.
  * Display: Fixed crash in GDI minidriver when displaying interlaced video
    with a 0x0 pane.
  * DV: Fall back to subsequent frames if the first frame has invalid audio
    metadata.
  * Capture: Fixed preview window being the wrong size when
    filtering/cropping is enabled and preview acceleration is off.
  * Capture: Fixed inconsistency in capture timing defaults. This only
    matters if you haven't already run VirtualDub in capture mode once.
  * Capture: The AVI superindex/subindex settings now also apply to captures.
  [regressions fixed]
  * Filters: Fixed error in IVTC computations for RGB32, YUY2, and UYVY
    formats (since 1.9.1).
avivahl
Posted: Jul 6 2009, 10:34 AM
Thank you for your wonderful work.
Much appreciated.
lroi
Posted: Nov 25 2009, 05:30 PM
a thousand thanks...you guys are so amazingly thoughtful and generous to be developing and sharing this wonderful tool with the universe...
gratefully, l
zhuzhu8376
Posted: Dec 23 2009, 03:24 AM
Thanks for your hardwork.
Much appreciated.
freedabu
Posted: Dec 31 2009, 09:53 PM
Thanks...........
4 replies since Jul 5 2009, 11:52 PM Track this topic | Email this topic | Print this topic
