| Posted: May 8 2009, 01:16 AM |
Changelog:
| CODE | Build 31953 (1.9.2, experimental): [May 7, 2009] [features added] * UI: Added support for configuring keyboard shortcuts in edit mode. * UI: Added Always on Top to window menu. * Filters: Filter cropping dialog is now resizable. * Filters: Added align-to-2 option in resize filter. * Filters: ELA and Yadif modes of deinterlace filter are now optimized for CPUs that have MMX but lack SSE2. * Filters: The filter preview window now has the same context menu size and filter options as the main panes. * Filters: Frame conversions at the start of a video filter are now cached. * Filters: Fixed rare crash when downsizing 8-bit YCbCr images with resize filter. * Filters: Improved frame allocator assignment for lower memory usage. * Filters: Added field delay filter. * Render: Added an option to warn if no audio is written on a save operation. * Render: Fixed several blitter bugs, particularly those involving 4:1:1 sampling.
[bugs fixed] * Preferences: Audio buffers value was set incorrectly exiting the dialog. The value show when the dialog appears was correct. * Filters: Fixed positioning issues in the filter cropping dialog for small frame sizes. * Filters: Filters now receive finite mFrameCount values in render mode instead of unspecified (-1). * Filters: Yadif mode of deinterlace filter was not caching internal frames efficiently. * Filters: Fixed crash in certain paths when a filter frame request fails. * Filters: Fixed occasional crashes with aligned scanline requests, particularly with cropping. * Filters: Fixed artifacts in resize filter on right border with certain filter+ratio combos, pre-SSE4.1 CPUs, and YCbCr formats. * Capture: Custom video format had HDYC listed twice instead of HDYC and v210. * Images: Fixed hang in PNG encoder. * Render: Added workaround for random hang when aborting render while using XviD with threaded compression enabled. * AMD64: Fixed crash in resampler with certain filter/ratio combinations.
[regressions fixed] * UI: Timeline scrubbing is more responsive again when dealing with files that have long delta frame runs (since 1.9.1). * Render: Fixed hang if there is a string of duplicate frames longer than the video pipeline (since 1.9.1). * Filters: Fixed some caching and frame numbering issues with filters that have non-zero lag (since 1.9.1).
| Barough |
Posted: May 8 2009, 04:30 PM |
Thnx 4 the new Experimental release phaeron
Hope that a new Stable release will show up in a 'near' future
