Virtualdub 1.8.6 (30009) Released
Posted: Sep 21 2008, 07:28 PM
Build 30009 (1.8.6, stable): [September 21, 2008]
  [bugs fixed]
  * Wheel scrolling in the Set Text Information dialog clos`es the edit control.
  * Save Segmented AVI now works with VBR audio.
  * Animated GIF export now fails with an error if the current output format is
    compressed or otherwise not supported.
  * JobControl: Fixed crash when one machine attempts to run a job in
    distributed mode right when another machine deletes it.
  * JobControl: The filter crop mode saved in jobs was opposite from selected.
    (This only affected YCbCr cropping.)
  * Capture: Fixed crash when capture driver sends audio samples when
    DirectShow graph is not running.
  * D3D: Fixed sporadic crash on lost device.
  * D3D: Fixed Direct3D errors when display debug information is enabled and a
    video filter fails to initialize.
  * Frameserver: Frame rate adjustments weren't always propagated correctly.
  [regressions fixed]
  * Fixed crash when using fast/normal recompress mode without a video codec.
  * Fixed divide by zero crash when loading video and a video filter in the
    list is unable to initialize.
  * Changing the "source rate adjustment" option no longer invalidates the
    current selection.
  * Rendering would loop endlessly if an error occurred during video
    compression and threaded compression was disabled.
  * Disabling the "directly decode YCbCr formats" option works again.
  * Filters: lMicrosecsPerFrame and lMicrosecsPerSrcFrame were reporting
    milliseconds (broken since 1.8.0).
  * JobControl: Fixed case where a non-distributed "load job list" command can
    fail due to erroneously running distributed-mode code.
  * JobControl: Fixed problem where dialog would suddenly close when editing
    job names.
  * Script: Fixed crash when removing video filter from filter chain.
  * DV: Audio decoding works again with NTSC DV files (broken since 1.8.4).
Barough
Posted: Sep 21 2008, 11:48 PM
But the download links @ http://virtualdub.sourceforge.net/ still points to v1.8.5
Posted: Sep 22 2008, 03:05 AM
Fixed.
Barough
Posted: Sep 22 2008, 03:11 AM
olnima
Posted: Sep 22 2008, 08:55 AM
Thanks very much for the new version !!!
Olnima
peter100m
Posted: Sep 22 2008, 06:21 PM
Thanks phaeron, another fine release!
chornobyl
Posted: Sep 22 2008, 09:40 PM
Nice to hear it, new versions are allways wellcome,
but
where could i find "1.8.X2 test releases"
and what "experimental features" it got
Posted: Sep 23 2008, 04:29 AM
Experimental releases are posted in the testing forum.
7 replies since Sep 21 2008, 07:28 PM Track this topic | Email this topic | Print this topic
