Virtualdub 1.7.4 Released
Posted: Sep 22 2007, 11:01 PM
Changelog:
Build 28204 (1.7.4, stable): [September 22, 2007]
  [bugs fixed]
  * Fixed bug where frame regions were shifted instead of extended to fix key
    frame violations in direct video mode.
  * If a video filter errored out during start phase, already initialized
    filters didn't receive end calls.
  * Toggling the "show decompressed video" setting in Fast/Normal Recompress
    modes could result in a crash.
Posted: Sep 23 2007, 03:32 AM
I've just seen that the new source code is Visual Studio 2005 only. Bummer. sad.gif
I've played with VS2005 before, but my impression of it was not favorable, and I didn't keep it. I'm wondering if I can adapt your new source into a Visual Studio 6 project. Do you think that can work? Is there anything in the plain C++ code that is VS2005 specific?
As always, thank you for the new VirtualDub release!
Posted: Sep 23 2007, 08:22 AM
Well, out of curiosity, I managed to get 1.7.4 to compile with the 1.6.19 compile setup (VC6SP5+PP):
http://www.virtualdub.org/beta/VirtualDub-....4-vc6patch.zip
Part of the reason this is doable is that I hadn't stripped out all of the VC6 conditionals in the source code. This is most definitely not a supported patch though... there are some pretty awful #define hacks in there, and I'm not at all confident that there aren't more issues lurking. The biggest problem I ran into is that VC6's compiler sucks horribly bad on templates -- I managed to crash the compiler several times and had to do some pretty bad rework of a few places that were using explicit member function template instantiation.
As a side note, fewer changes would be necessary for VS2002 or VS2003... VS2002 has for scoping, and VS2003 has MUCH better template support.
olnima
Posted: Sep 25 2007, 06:25 PM
Thanks very much for the new version, no problems so far :-))
Olnima
3 replies since Sep 22 2007, 11:01 PM Track this topic | Email this topic | Print this topic
